Forum: Old versions
Topic: Need help connecting my dj controller to virtual dj
Hey guys would someone be able to answer a quick questions for me. I just bought a Numark Mixdeck and i am having trouble setting it up to virtual DJ. When i plug in the USB cables the computer recognizes the controller but it's not identified in virtual DJ. Can anyone please help me. How do i connect my controller to virtual dj?
Posted Wed 26 Oct 11 @ 7:41 pm
Which version of Virtual DJ are you running?
You probably are using an older version which doesn't support the Mixdeck. Either register your software or download the free home version, https://virtualdj.com/download/free.html
With the free version you can use your controller for 10 minutes at a time, this is so you can get a feel for how the program will work with your controller. If everything goes smooth you will need to buy the "PRO" version.
Good Day
Huey
