JUST PURCHASED NS7 HOW DO I GET IT TO WORK WITH VDJ????
Posted Wed 26 Oct 11 @ 5:14 am
You need to install all drivers for the ns7 and serato itch on computer. once that is done you can use your ns7 with VDJ. Remember if Itch is not installed on computer NS7 will not work with VDJ. Make sure that you connect your NS7 to a usb port on the computer and not on USB hub as hubs can cause issues.
Posted Thu 27 Oct 11 @ 1:57 pm
