Just up graded laptop...
Toshiba satellite i7 quadcore 2.3 processor
8gb ram
1gb nvidia graphics card
windows 7 64bit
latest version of vdj 7.0.5b
2 denon 3700 midi mode
latest firmware
1490 pulse rate
midi channel 1 on both
using gamebooster pro as well.
Ok here is the problem. All connected and working. Both decks working as they should. Im a video dj. So using videos. Everything loads ok. Starts playing then every now and then sounds like skipping fast forward or stuttering a little.. Tried changing latency in denon asio to highest..deck becomes unusuable and still skips... Any ideas. I was using my behringer bcd3000 and works perfectly...but really want to use my denons.... I also use serato for djing. So i thought using my sl1 soundcardand using timecodes..but vdj doesnt recognise the soundcard...it does on old vista lapto...strange...help....
8gb ram
windows 7 64bit
latest firmware
1490 pulse rate
Posted Mon 17 Oct 11 @ 2:24 am
mayb u need VDJ timecodes
Posted Mon 17 Oct 11 @ 2:27 am
Na..thats not it..the denons should work in midi mode.. Also vdj doesnt even recognize sound card to be able to use timecodes or hybrid midimode on the denons....but thanks
Posted Mon 17 Oct 11 @ 2:39 am
