NUMARK Mixtrack Pro
Virtual DJ Pro FULL
I am a regular DJ in my home town. I use my MIXTRACK Pro with gigs every Friday, Saturday & Monday. Recently i have been asked to come & play at one of the night clubs in my area.
Last night whilst DJ'ing with my MIXTRACK Pro i came accross a very BIG problem which i have yet to see identified by some one else on the VDJ website.
Whilst i was playing music on Deck B, i selected my next song to be mixed in on Deck A. The song loaded onto Deck A fine and i hit the sync button to match the BPM with Deck B (This also worked fine). As i hit the play button for Deck A i noticed that the music did NOT begin to play, but the play BUTTON highlighted itself and stayed lit on both the controller & VDJ as if the music was playing, but no sound, no visual.
I absolutely crapped myself last night and began to try everything to resolve the problem. It seemed that everything on Deck B was working absolutely fine & also everything on Deck A (Besides the Play button & also the jog wheel) was working fine. This happened to me atleast 3 times last night, all at complete random times and then suddenly worked again completely randomly. Strangely enough this only happened on Deck A.
My MIXTRACK Pro is NOT the problem as i used my mouse to select the play button and still VDJ responded exactly the same. I am extremely dissappointed with this, luckily only once my song on Deck B ran out and i managed to recover without looking like such a dick but i am not looking forward & do not feel confident now with my VDJ to play in a night club.
Any help would be muchly appreciated!
HouseJunky
    Virtual DJ Pro FULL
HouseJunky
Posted Tue 11 Oct 11 @ 8:04 am
          If this happens then it means that your sound is not configured correctly or there is a problem with the sound driver - Please see http://www.virtualdj.com/wiki/Song%20wont%20play%20when%20pressing%20PLAY.html
Please register your Pro serial number on the page http://www.virtualdj.com/users/edit.html and then download the latest version from http://www.virtualdj.com/download/updates.html (NOTE: MixTrack Pro entitles you to a significant discount off the cost of upgrading if it came with VirtualDJ LE.)
Once you have done this, check that your sound is configured correctly: http://www.virtualdj.com/wiki/MixTrack%20Pro.html
If you are not using the sound card built into the MixTrack Pro, then make sure that you have that latest drivers installed for the sound card(s) that you are using. If you are using two separate sound cards, then this issue might be because they are not compatible with each other. Using a dedicated multi-channel DJ sound card is strongly recommended for live performance (The MixTrack Pro has one built-in.)
Posted Tue 11 Oct 11 @ 8:09 am
          Thankyou very much for your immediate reply!
When i saw your reply you actually brought to my attention that i hadnt installed my ASIO driver for the mixtrack pro on my new laptop. Hence the sound drivers not being configured properly! Thanks your a huge help, hopefully this has solved my problem and I won't come accross it again! :)
Posted Tue 11 Oct 11 @ 12:40 pm
