Hi
i want to buy the american audio encore 2000
it says it works with vdj but is there a special skin for this or do i just connect it with the laptop?
Posted Sun 09 Oct 11 @ 7:32 am
It comes bundled with Virtual DJ LE so it should just be plug and play.
Posted Mon 10 Oct 11 @ 1:31 pm
Good day all,
i just want to know when is the availability of Encore 2000 skins here in virtual dj...
the player is good, but mixer is not working in the computer.. please advise me...
thank you..
thank you..
Posted Thu 26 Jan 12 @ 6:25 pm
djreyco wrote :
Good day all,
thank you..
thank you..
The Encore has an analog mixer on board so it uses the faders and eq from the mixer instead of VDJ. You can if you like map the faders and knobs as Fake in VDJ if you realy need to see the movements on the computer screen. I am not sure if it is possible to use only volume and eq from VDJ by setting the Encore to post EQ (can be done on VMS4). But you do not want to have the EQ knobs work bouth on mixer and VDJ as it will work as doubles.
SO really it's nothing wrong with mixer on computer just the way it's suppose to work.
Posted Thu 26 Jan 12 @ 6:36 pm
THis machine is worth much more than its value i have it....i can post videos of me scratching on it, its beef , but im wondering if there is any firmwar
e update
e update
Posted Fri 30 Oct 15 @ 1:57 pm
