my mixer works just need to know how to map earphones not working. on midi working on usb. so i know it's not the mixer. i was playing in the control panel and caused a midi map error. also does anybody know how midi map pfl button on the mixer. i want to map it to do two things if it is possible i want to turn it into a sync button and to switch it to a earphone moniter. currently i push it to turn on the moniter for the earphone since there are two for each channel.
http://www.adjaudio.com/ProductDetails.aspx?ItemNumber=1468&MainId=1&Category=Mixers
see the those two buttons lighted up above american audio words on mixer i want to turn those into sync buttons and earphone monitors. if i can only map it one way i rather just use them to switch ear phones on and off on those channel s.
thanks....!
thanks....!
Posted Fri 07 Oct 11 @ 11:20 pm
