Forum: Music discussion
Topic: Hide song title while broadcasting using VDJ/Virtual DJ
After searching for the answer here, noticed nobody really answered this question so for those who need:
To hide song title while broadcasting using ONLY VDJ/Virtual DJ is simple:
Open computer registry editor tool (Run > regedit (press enter))
then go to HKEY_CURRENT_USER\Software\VirtualDJ
select string "BroadcastShowTitles" and double-click to edit value. Value should be "0" to hide, "1" to show.
Posted Fri 30 Sep 11 @ 5:15 pm
cool =)
Thanks!
System: MacPro 10.9.4 // How can i hide song titel with my Mac? pls Help!
THIS IS WHAT I FOUND MOST USEFUL....
JUST GO INTO OPTIONS....OPEN IT UP ALL THE WAY......
THEN SCROLL DOWN TO THE BROADCAST TAB.......
THERES A SELECTION LABELED " broadcastsonginfo "....
CHOOSE NO....
POINTMAN BLACKCHAIN... many thanks! - For those who can not find it simply follow POINTMAN BLACKCHAIN's instructions and then search for - broadcastsonginfo - click on NO and save the options by closing the window. simple! Many thanks Pointman!
how can i hide using mac? thru vdj?
Tried this option and it still shows in the video.
turn off the video skin
Hi i dont find the broadcast in vdj 8.0 and i also tried the first and no luck any other way to not broadcast song info? cheers
Just look for broadcastSongInfo in Settings=>options - and set to "no" if you dont want to send titles
For broadcast you might also want to have to look at broadcastSongInfoFormat where you can change what to display
