My understanding is that a pro license is required for using the LPD8...Is this true of all midi controllers? For instance Hercules...
Posted Tue 27 Sep 11 @ 12:57 pm
No, not for ALL controllers...
Because some controllers are designed for DJing, and ship with a Lite (controller specific) version of VDJ.
Other controllers, such as the LPD8, are just for general use - and as such don't ship with software.
So if you buy something like a Numark DJ2GO controller (very low cost) you'll get VDJ included, which will work with that controller.
Posted Tue 27 Sep 11 @ 1:10 pm
But remember that the DJ2Go is NOT an LE version - it's a LITE version. So very much limited at all !
Anyway - the LE or Lite versions only work with the Controller they get delivered with.
Greets, Heiko
Greets, Heiko
Posted Tue 27 Sep 11 @ 1:42 pm
