Hi
I´m a beginner who just bought the Hercules rmx console and the software Gemini Groove pro. I connected the output 1-2 Rca to my amp and my headphones to the front output on my Rmx console but when i turn up the volume to the headphones nothing happens, and when i press the Cue Select the volume that goes out thru the amp goes up. Have i connected it wrong ?
I also tried to connect it thru a Dj mixer and had the mixer set to Line and when i did turn up the volume the sound was just awful, like the speakers were broken. I connecter the Rca 1-2 out and in to one channel of the mixer (Line)
Can i somehow connect it so ive got Deck A to channel 3 on the mixer and Deck B to channel 4 ?
The mixer i´ve got is OMNITRONIC MX-420B.
Posted Tue 27 Sep 11 @ 7:01 am
Your sound settinngs may be incorrect and/or you do not have the latest firmware and drivers installed.
Please see https://virtualdj.com/wiki/RMX.html
Also, check that the input on your mixer is set to line and not phono. If you connect to a phono input (Or line input set to phono), you will get a very loud distorted sound.
Posted Tue 27 Sep 11 @ 10:18 am
I have Virtual dj 7 pro full and I use a Hercules RMX but I cannot hear anything through my headphones unless I load the VDJ5 series that came with the mixer. Please Help?!!
Posted Thu 12 Apr 12 @ 7:41 pm
As above, please ensure that it is configured correctly and has the latest drivers and firmware installed:
Posted Fri 13 Apr 12 @ 5:07 am
