Hi, i need help :P
Simply how do i loop like this at http://www.youtube.com/watch?v=LwmDRliXQps from 20 seconds to 26 seconds, skrillex does a loop that overlaps the song, meaning the song continues playing even though the loop is looping, then when hes finished looping it goes back to the song.
Thanks alot :)
Thanks alot :)
Posted Fri 23 Sep 11 @ 2:06 am
I havn't seen the video, I'm at work, but it is probably loop roll, to download it you need to be full registered pro user.
for the settings you would set the loop length to whatever size and set the wet/dry to 50%, it is an amazing effect that you can do way more fun stuff with that makes the purchase price of vdj worth it.
Posted Fri 23 Sep 11 @ 2:39 am
