As you've already probably read in the title, my midilog (bass, treble, gain, mid) knobs do not respond.
I've connected a simple Logitech speaker system to the outputs of the rear panel and I've assigned my CF A to channel 2 and CF B to channel 3.
It's working really well, except for the midilog knobs which I cannot use.
It's my first dj controller so bear with me please :p
Hope someone can help!
Posted Thu 22 Sep 11 @ 10:58 am
Can you please inform us about the version of VirtualDJ LE you use ? Check that at Config->Infos (last tab)
When using the EQ knobs they do not affect the sound output at all, or you simply can not see the knobs moving on screen ?
Try also to set the VMS4 to 8out mode (change that with VDJ closed and VMS4 powered off), set all midilogs to USB mode and check the EQs again.
Please register your VMS4 VirtualDJ LE software to your Profile page https://virtualdj.com/users/edit.html
Posted Thu 22 Sep 11 @ 11:44 am
Okay, I did that. I'm using VDJ LE7.
I also did what you asked. It was already set to 8out mode and all midilogs were also set to USB.
When I try using the EQ knobs on one of the midilogs, nothing happens and I don't see them moving on the screen as well.
Everything works perfectly fine except for the midilogs :(
Posted Thu 22 Sep 11 @ 12:56 pm
I had a VMS4, have you tried using the VMS4 in Post EQ mode? hold down channel 4 cue button when powering up VMS4
I remember I had to do this to be able to map the EQs.
But I'm not sure if your Virtual DJ LE will allow you to map it.
Posted Thu 22 Sep 11 @ 3:59 pm
