Forum: Old versions
Topic: American Audio VMS4 Audio Problems
Recently got the VMS4, I have now completely lost sound to it, Im quite new and this is my first deck, but for the setup on the peice of hardware I seem to have gotten everything, but now I get no sound from headphones or my laptop. Please! Help!
Posted Tue 20 Sep 11 @ 5:09 pm
You're not supposed to get sound from your laptop!
The VMS4 is a real mixer. When you plug it in to your PC USB socket and use DJ software, the sound gets sent out of the PC into the VMS4.
To hear it, you have to plug either powered speakers or an amp into the VMS4 output sockets.
You also plug your headphones into the VMS4, so you can cue tracks.
Will the VDJ V7.0.5 support the VMS4??
Yes, it's been supported for a while now.
Even if it didn't have mapping supplied, you could do it yourself.
thanks buddy
I have the VMS2 and i am suffering similar problems, probably because i am a begginer also, I have plugged my external pc speakers into the master output on the device and still no sound. the only time i can hear anything is when i plug the headphones in on cue mix and then i can only hear channel 1. any suggestions???
