When I start the VDJ, The software recognizes both the Decks to one deck.
So when I play the right deck, the left deck play to, they working togeter.
What should I do to fix the problem?
Tnx :)
Tnx :)
Posted Sun 18 Sep 11 @ 9:09 am
Try putting them on different MIDI channels.
Posted Sun 18 Sep 11 @ 1:03 pm
I try, its not that.
Posted Sun 18 Sep 11 @ 6:21 pm
Click config/mappers and then the top center button, then select the deck assignment there.
If its backwards, just push eject on either deck to swap it out.
Please register your pro software serial number in your member profile for the best results using the latest version in your download center.
Posted Mon 19 Sep 11 @ 5:03 am
