Forum: Old versions
Topic: Numark Mixtrack Pro response to LE and PRO issue
I am running Virtual dj on a PC. I have a Numark Mixtrack Pro. The issue I am having is the response time. There is a huge response time difference when I use my Numark Mixtrack Pro on LE vs PRO. The response time is a lot faster when using LE. I can use my hot cues as a stutter. When I am using PRO, the response time is a lot slower. When I press a hot cue on side A and B at the same time, they will not play on time of each other. One response will always be late. I do not have this problem at all on LE. It doesnt make sense because PRO is a better version than LE, so I shouldnt be having this problem. And when I switch between the products, the LE still works a lot better than PRO
I have a Numark DJ io asio driver that im using, and it is set to 49 samples - 2.7 ms. Which is the best to go to. but even without this asio driver, I am still having the same issue. PRO has many options that you can change, versus LE, that you cant change any options. So what do I do?
So I know that its not my controller thats messed up, its the 2 programs. I am using PRO 7.0.4
Posted Tue 13 Sep 11 @ 10:18 pm
The first thing that you need to do is register your Pro serial number on the page https://virtualdj.com/users/edit.html and then download the latest v7.0.5b version from https://virtualdj.com/download/updates.html
If you are using an illegal version of Pro, this may be why you are experiencing difficulties.
It's also possible some of your performance settings in Pro are not set correctly, or you may have auto sync features such as smart play or smart cue enabled - See https://virtualdj.com/wiki/Turn%20off%20auto%20sync.html
NOTE: LE is simply a cut down version of Pro, so there should be no differences between using either version.
