I bought a NS6 about three weeks about after my mixer died during a show.. It came bundled with Serato Itch and after using Serato Scratch Live several times I decided to try that out. I really liked it however, version 2.0 is very buggy. However, it did update my comments on my music. Why this is imporant is because I use a program called "Mixed in Key" and that writes the key into the comments to the ID3 tag. I have tried to re-anaylze the tracks and still does not update. Its kinda odd, because some already show the updated tag and some do not..
The other issue I am having is the NS6 setup. I can not get it to show "NS6 ASIO". The only way I can get it to work is to go to advance setup and configure it that way. Which isn't a problem, it just isn't the way I read on these forums.
Virtual DJ 7.0.5B
Macbook Pro 13" 2010
Snow Leopard 10.6.8
Thanks for your time and help
Virtual DJ 7.0.5B
Snow Leopard 10.6.8
Posted Mon 12 Sep 11 @ 8:02 am
IN the browser window, right click on the title bar.
It will give you a dropi down list. Check Key and you
should be good to go.
Posted Mon 12 Sep 11 @ 9:56 am
It doesn't show the key that is found with mixed in key.
Posted Mon 12 Sep 11 @ 12:03 pm
This is a common issue. VDJ sucks are reloading key and comments ID3 tag info.
If its just a few tracks do it manually.
If its a bulk change i use 2 methods.
1 - Delete entire VDJ database (hence losing all cue point and bpm info) and reload everything
2 - Open database xml in an editor and delete track info. Next time when you open VDJ it will act as if its seeing the tracks for the first time and load the updated ID3 tags. (this works best when you are updating most files in a specific folder).
Posted Mon 12 Sep 11 @ 3:46 pm
