Hi!
I'm running vdj (705b) with the pioneer ddj-s1 and the mapper by cstoll. downloaded from the vdj page.
it works, BUT.... cue-headphone doesn't work. cue-mixing beetween cue-master doesn't work too :-(((
the earphone does work, but only when using the fader (master). when using serato itch which is bundled with the ddj-s1, everything works... but it's serato.. :-(
I've tried another pc, it's the same
win 7
newest pioneer drivers
newest virtual dj
mapper by cstoll version 1.0
can anybody help me?
greets mexx
sorry for my english :-)
win 7
newest virtual dj
greets mexx
Posted Wed 07 Sep 11 @ 1:57 am
This has nothing to do with the mapping, you got probably wrong audio settings, most likely the master and headphones are swapped.
Audio settings :
Inputs : None
Outputs : Headphones (Master : Chan1&2 / Headphones : Chan3&4)
(Here you have the option to swap outputs if needed)
Soundcard : Pioneer Ddj ASIO
Audio settings :
Inputs : None
Posted Wed 07 Sep 11 @ 6:04 am
cstoll mapper not necessary , Ddj-S1 is supported in V 7.0.5b ;)
Posted Wed 07 Sep 11 @ 6:31 pm
To config the Headphenes correctly you have to go to (>config >Sound Setup) under outputs: select (>Advanced Config) click the (+) to add a second stereo channel. on the first channel select (>Master >ASIO4ALL V2 ASIO >Output 1&2).... on the second channel select (>Headphones >ASIO4ALL V2 ASIO >Output 3&4) click Apply and OK... :) This is what worked for me because when i would select the (Line Pioneer DDJ-S1) for both master 1&2 and headphones 3&4 the sound would always come out of both master and headphones and the PFL buttons would not work. Well I hope this helps you guys.
Posted Tue 20 Sep 11 @ 4:56 am
