Forum: VirtualDJ Skins
Topic: Skin concept - Page: 8
1388x ????
I thought 1366x is the standard....
1366X version is coming out next week ;)
Just to confirm, 1366 will be fine :)
And after your finished with Charlies request,can u make me 2 @ 1280x800 AND 1400x1000?...he,he..just playing...I mean u dont have to...
.....:-P
I resized to 960 x 600 LOL it looks great, amazing work phantom :)
I loaded this skin on to my spare gig machine which is 1440x900 and it looks great.
I love the skin and will get a buzz out of it each time I load it up.
I took the time to review the skin and highlight suggestions.
Also I can't get used to the pause buttons been to the right of the play buttons.
First night on the job with it, it was great.
I will fix that on the next update. I thought I copied the physical layout of the original skin but it seems that I messed them up.
On my skins I only use TWO control buttons...
Also to consider for the next update is the feature of advanced manual bpm correction.
In the default skin on the deck (top right corner) if you right click on the BPM button it opens the bpm/beat gird editing panel which is very handy for on the fly gird corrections.
Did you tried to right click on the "sync" button ?
Heres an idea,
You could have video 2 mode, basically the same but with scratch panels as well.
This image is just something I knocked up and isn't accurate, i.e. the lines dont line up and one of the scratch colours is wrong but you get the idea.
fantabulous, thanks.
Todays game:
Spot the differences!
Skin just looks better and better.
You found most of them. You only missed the small white dots next to the deck selectors ;)
I\'m working on the 1600x900 (extra wide) version right now since it requires less time to complete (resizing a skin up is always easier than resizing it down)
So, how does this looks ? Is it ok with you ?
Yeah looks great
Looks great, but having difficulty seeing what's changed... lol
Roy
It has scratchwaves on the left/right side of the mixer
So it does... very cool
Dear PhantomDeejay
You did a fantastic job.
Could I ask about two wishes for me?
1. A Resolution 1280 x 800 for my MACBook 13"
2. Please change the colour and perhaps the Layout of the desks.
Colour:
Deck 1: Yellow - Deck 2: BLUE - Deck 3: GREEN - Deck 4: RED
Layout:
Deck 3 - Deck 1- Deck 2 - Deck 4
In my opinion this is the best colour layout to work in clubs where the light is shutdown.
Beautiful Greetings
chris
74%
