Forum: VirtualDJ Skins
Topic: Skin concept - Page: 11
Was kinda hoping not, but think this will be the case now unfortunately...
Cheers,
Roy
I would like to inform you guys on a couple of things...
First, resizing a skin like CDS4 requires a complete re-write of the entire XML code, which is very time consuming.
Secondly, in the middle of the procces I have discovered some "flaws" on the initial code.
Now, the most interesting part:
I will update the skin with a 1366x768 resolution very soon.
However I'm not going to update the skin with other resolutions for the moment...
For the fans of the skin I have a little surprise...
I have redesigned the entire skin from scratch (graphicaly-wise).
I have "included" several new options and functions that will make this skin even more customizable AND CLEAN.
However, since "coding" the CDS4.1 will require a tremendous amount of time, I will "hold" it until VDJ 8 comes out...
Right now I feel that this is the most wise thing to do. Once 8 comes out and be able to see it's changes I will resume the project including/excluding the parts that may need to change...
Thank you for your patience, and sorry for all the delays...
Thanks for the update
Ta For Info , great Skin
Oh shi...now im all curious about this surprise.
thanks for the update.
Thanks for the info ;o)
Hope VDJ 8 coming out soon...
i have re sized CDS4 to 1366x768 using skin re size tool. appears to work ok for me ,although high ,mid,low controls look incorrect. i have tried to get a daytime skin which seams o k except that the top waveforms do not show.is there a way to get the waves showing,? Help please if you can
Old skin work with VDJ8 so why don't we start working on it again?
I am ready for the surprise, give it to me now!
i love surprises to
Why have you re-ignited this one Charlie?? lol
Heh, I am conflicted about switching to VDJ8 because I wont be able to use this skin for now.
this skin is very best
I'm still waiting for the surprise bro!
Ditto...
