exe. doesn't greate a shortcut when I'm installing? And the when I open VirtualDJ through administrators shortcut it says: Installation error! Please reinstall VirtualDJ from the offical installer. If you have multiple use accounts on this computer, make sure you install from the account you're using, not administrator... Well, that's exactly what i've done, any ideas? I run windows vista...
Posted Tue 06 Sep 11 @ 10:59 am
What version are you trying to install?
Posted Tue 06 Sep 11 @ 11:12 am
7.0.5
Posted Fri 09 Sep 11 @ 12:02 pm
u still having the problem?
Posted Tue 20 Sep 11 @ 1:21 am
Yeah, any idea how i can fix that?
Posted Fri 23 Sep 11 @ 12:12 pm
Is this an LE version, Home, Pro? Where did you get this from? Did You put in a ticket to support?
Posted Fri 23 Sep 11 @ 12:26 pm
Do you have a licensed copy?
Posted Fri 23 Sep 11 @ 2:49 pm
I downloaded it from this website, and it's VirtualDJ Home FREE
Posted Sat 24 Sep 11 @ 1:50 am
First thing I'd suggest is to dump Vista!
Seriously, upgrade to Windows 7 - it's way better than Vista.
Posted Sat 24 Sep 11 @ 4:01 am
Yeah I know :D Well I fixed the problem with running VDJ as admin :D
Posted Tue 27 Sep 11 @ 1:27 pm
