I am wondering if there is any one out there that could add a few rotary's and switch around some of the mapping on my MTP. I would also like to rebuild in an aluminum chassis and put pro quality sliders and rotary's on the entire controller. Maybe even arcade buttons for the sync, cue and play and eliminating the 4th button all together as I have never and will probably never use it. THANKS FOR THE HELP!!!!
Posted Fri 02 Sep 11 @ 1:43 pm
Sounds like a great winter project for ya...........show us some pics when your done with it.
Good Luck
Huey
Good Luck
Huey
Posted Fri 02 Sep 11 @ 2:19 pm
well I know I cant do it my self....but I am thinking that there is a company out there that can maybe....I want to make so it can function way better with VDJ....I love me some VDJ it has brought pure happiness for the past 6 months!!!
Posted Fri 02 Sep 11 @ 2:29 pm
While you might not be able to add switches and stuff you could surly measure out the unit and build the aluminum case yourself. The hard part would be mounting it inside but then again you never know unless you try ;-)
I say give it a shot,
Huey
Huey
Posted Fri 02 Sep 11 @ 3:52 pm
I disagree, why not just get something with better components to begin with? the mixtrack is designed to last maybe 12 months before it breaks, then you will need to upgrade, that's why it costs very little, it's like a junkies first hit,
at the moment you have speed (mixtrack) that your dealer is giving you at cost price, sure you could mix in a little ecstasy (any other cheap controller) and still get a buzz, but you my friend are a junkie... I wouldn't go for PCP just yet (ns6/s4) that will f@#k your mind up at this stage, but some good crack/meth/heroin (reloop/vestax/pioneer) will get you high for now, until you can source more coin for your habbit.
P.S. I would stay away from acid/LSD (touch screen) as you just don't have enough control over it's effects, at least until they refine the recipe.
Posted Fri 02 Sep 11 @ 8:57 pm
LOL!
LOL!
Posted Fri 02 Sep 11 @ 11:25 pm
I just thought of another good one... weed (dj2go) it's good for sitting around with your mates, but only going to leave you seriously lacking when performing... And maybe snorting cocaine of a marble table with a C note with a penthouse full of honeys sippin on cognac (pioneer 2000 series) every mans fantasy LOL
Posted Sat 03 Sep 11 @ 1:07 am
that made my day lol
Posted Sat 03 Sep 11 @ 8:20 pm
