Many dance and techno songs use a woosh-sound as a climax in songs. Examples being: http://www.youtube.com/watch?v=Q3MvN8BsbOc at 5:27 and 6:27. Does anyone know what this is and how to get it?
Thanks!
Thanks!
Posted Thu 25 Aug 11 @ 3:46 pm
It sounds like it is part of the track production, its a white noise through a synthesizer with a lfo filter to give it a wavy effect... tex has built a fantastic effect called "noisebell" it sounds similar but is a bit more resonant and brighter than white noise, that said, it still sounds great...
slider 2 is what makes the sound, I would turn the highpass and pink noise buttons on and turn down the resonance.
Posted Thu 25 Aug 11 @ 4:25 pm
Thanks synthet1c, I appreciate the response. I'll check that out when I get home and see what I can do.
Posted Fri 26 Aug 11 @ 9:41 am
It works like a charm! Thanks again.
Posted Wed 14 Sep 11 @ 9:36 am
That is a good effect, thanks for sharing, can't wait to use it. I'm searching for one thats similar to the above mentioned but with a backspin in it. Hard to describe, I hear it used on the radio allot.
Posted Wed 14 Sep 11 @ 4:50 pm
google white noise,
Posted Tue 20 Sep 11 @ 1:09 am
