S I was told by a fellow DJ, that since I use both VDJ Pro and Searto Scratch live, I should have two separate hard drives, one for serato and one for vdj. I copied library to external for serato and imported so far so good. But cant figure or find a way to export iTunes library to external and import into vdj pro. Anyone do this? Anyone have simple instructions on how to go about getting my whole song and video library to this hard drive ? I tried copying the files the iTunes media folder but that had separate folders by artist and not a conveinient way to retrieve songs. Ay help and guidance would be grateful for. Thanks.
Posted Wed 24 Aug 11 @ 10:15 pm
You don't need to use two separate drives. The same drive can be used for both software. Each has its own database, so will not interfere with each other.
iTunes library on an external drive is not currently supported (Although you can add the music on the external drive so that you can find it when searching in VirtualDJ - Browse to the drive in the VirtualDJ folder list, right-click on it and choose Add to search DB.)
NOTE: Make sure that you always have a complete and fully up-to-date backup of your entire music collection as well as your VirtualDJ database if the information stored in it is important to you (BPM, comments, etc.)
Posted Thu 25 Aug 11 @ 5:47 am
