I am having trouble with my vms4 on virtual dj, when i touch the jogwheel and pull it backwords and let go it has a brief second until the music starts playing again, until the jog wheel stops moving it will not immediatly start the music again. When i push forward it does not do this, even if I whip the jogwheel forward and let go... it starts playing normally again.
When I touch the jogwheel and move backwords it does the backwords motion scratch and if I keep spinning it continuously but on the side without touching the top it continues to be in the "scratch feature"... how can i map this so when i let go of the top it continues normal play immediatly
Posted Wed 24 Aug 11 @ 3:26 am
Please do not post the same message more than once.
You have asked this same question in the following topic, where you can find an answer: https://virtualdj.com/forums/152754/Hardware_Technical_Support/Need_help_with_VMS4.html
Posted Wed 24 Aug 11 @ 7:30 am
