ok, im so frustrated with all of this. im new to the whole controller thing so trying to hook all of this up is so so so frustrating. i have my stealth control and djio hooked up but the frustrating part is setting the right config on vdj. i cant get my tascam speakers to work, i dont know if i have the speakers in the right input on the djio. this is just all confusing. i need the right config for vdj so i can hook up the tascam speakers and have my samson headphones hook up to the djio. i basically had it working but i couldnt play one song over the speakers and have the other deck playing on my headphones to prepare it to be mixed, thats basically all i want to be able to do is prepare a song on the headphones. i need help so if anyone knows a video tutorial or anything that would help me get all of this set up id really reallly appreciate it. thank you. im so frustrated. :(
Posted Tue 16 Aug 11 @ 10:37 pm
running vdj 7 btw.
Posted Tue 16 Aug 11 @ 10:38 pm
Which version of VDJ 7 are you running?
Posted Wed 17 Aug 11 @ 5:59 am
Please see https://virtualdj.com/wiki/DJIO.html on the page https://virtualdj.com/wiki/Controller%20Configuration%20And%20Troubleshooting.html
You will need to purchase the full VirtualDJ Professional to use MIDI controllers such as the Stealth Control: https://virtualdj.com/buy/
If you have already purchased, then please register your serial number on the page https://virtualdj.com/homepage/jpboggis/ and then update to the latest v7.0.5 version: https://virtualdj.com/download/updates.html
Posted Wed 17 Aug 11 @ 7:19 am
