So I bought the mixtrack pro today, everything is working fine but unforgettably I thought I just need to install the software and connect the controller and I can use it. It turns out that no sound comes out of my computer speakers. I looked around the forums for help and nothing is working. Right now I just thinking about buying some speakers. I just dont know what....do I just go to my retail store and as for some RCA speakers? And if I do buy some speakers will everything be fine or is there more that i need to buy? I have no headphones yet. Please help asap. Im also just thinking about returning the product first thing in the morning. I was really excited today because I took my first step on becoming a DJ...now it just ruin my day.
Posted Sun 14 Aug 11 @ 11:10 pm
Please check that the MixTrack Pro is setup correctly: https://virtualdj.com/wiki/MixTrack%20Pro.html
Make sure that you have plugged a pair of powered stereo speakers into the master outputs on the back of the console and your headphones into the headphone socket of the console.
Alternatively, connect a suitable cable (2x RCA to 3.5" headphone jack) from the master output of the console to the line input of your computer. The sound will then come out through the computer's speakers (If not, go to your sound card's mixer/control panel and ensure that the line input is not muted and the volume is set to an appropriate level.)
NOTE: VirtualDJ LE is limited software and does not support outputting sound directly through your computer's own built-in sound card with headphone pre-listening. It is designed to work with the sound card in the console only. For more flexible sound configuration options and much, much more, you will need to upgrade to the full VirtualDJ Pro at a discount: https://virtualdj.com/buy/
Posted Mon 15 Aug 11 @ 3:39 am
