Need help here guys. I already have the rmx and love it. However, I would like to be able to scratch a bit so was thinking about adding one Denon DN-SC2000. How do I hook up and configure for best results?
Posted Sun 14 Aug 11 @ 9:32 pm
Please explain why you can't use the RMX to scratch?
What makes you want to use the Denon instead?
Posted Sun 14 Aug 11 @ 9:40 pm
The Rmx jogs are not touch sensitive so there is too much lag on release.
Posted Sun 14 Aug 11 @ 9:46 pm
Ok - was just wondering - I have never used the RMX
Posted Sun 14 Aug 11 @ 9:49 pm
You would need to upgrade to the full VirtualDJ Professional at a considerable discount to use the DN-SC2000 or any other MIDI controllers alongside the RMX: https://virtualdj.com/buy/
With the full Pro, you can use multiple MIDI controllers at the same time. On the SC2000, there is a DECK button to switch between controlling the left and right decks.
Another option is to simply upgrade to an all-in-one controller that has touch sensitive jogwheels such as the new Hercules 4-Mx or 4Set or the Numark MixTrack Pro.
Posted Mon 15 Aug 11 @ 5:15 am
