does any know how to setup Pioneers CDj-800Mk2 to work with virtual dj?
have virtual dj pro 7
I have it like this right now https://virtualdj.com/image/84267/63802/SETUP.jpg
I get sound but I just don't know how to get the cdjs to work with virtual dj can any1 help me
also have this sound card http://www.amazon.com/Focusrite-Saff.../dp/B002R9ILOY
Posted Sat 13 Aug 11 @ 2:01 pm
you need to register your software firstly or it wont allow you to use them... then someone else will have to help you as im not too sure...
Posted Sat 13 Aug 11 @ 2:30 pm
going register my product right now see if that makes it work
Posted Sat 13 Aug 11 @ 2:42 pm
how do i register it?
Posted Sat 13 Aug 11 @ 2:55 pm
Jumpt to the Modify page and enter your serial code: https://virtualdj.com/users/edit.html
Greets, Heiko
Greets, Heiko
Posted Sat 13 Aug 11 @ 2:58 pm
ok entered it so now what do i do?
Posted Sat 13 Aug 11 @ 3:10 pm
In the first picture it says phono, that's wrong, it should be line. If those decks can be used as MIDI controllers then go into the rappers tab and assign them to there corresponding decks. As for you registering it must not be your copy cause it would of shown up under your name. Look under ours it shows our hardware and which versions of VDJ we have....
Good Luck
Huey
Good Luck
Huey
Posted Sat 13 Aug 11 @ 3:15 pm
yup, like mine
it says professional edition user.
Posted Sat 13 Aug 11 @ 4:27 pm
