Hi,im thinking about buying the numark mixtrack pro,but the problem is im on vacation in england,so i cant get virtual dj le with it.I tried asking customer support if mixtrack pro works with virtual dj home free,but they are yet to answer,so,i thought mabye the community would have some answers!
Posted Sat 13 Aug 11 @ 6:09 am
No, it will only work properly with the LE version supplied or VDJ Pro full.
Keith
Keith
Posted Sat 13 Aug 11 @ 6:19 am
Ok thanks!do you know any controllers similar to the it that work with the free version?
Posted Sat 13 Aug 11 @ 6:24 am
None of the controllers will work properly with VDJ home, however they will allow ten minutes at a time to use a controller or advanced sound configuration.
I know a few people have bought mixtrack pros with traitor as the program but have spoken to Numark and gotten the le version of VDJ.
Mixtrack pro is an excellent controller and I love mine.
Good luck
Dj Klepht
Good luck
Dj Klepht
Posted Sat 13 Aug 11 @ 7:19 am
Thanks guys!
Posted Sat 13 Aug 11 @ 7:24 am
i contacted numark and they generated me a vdj LE code instead of me having to use the traktor one.
shoot numark and email and ask if you can have a software exchange.
Posted Sat 13 Aug 11 @ 2:12 pm
0_0 i was about to spend 300$ on VDJ pro just so i could use the mixtrack,guess i dont have to!
Posted Sun 14 Aug 11 @ 5:05 pm
Is still rather get the pro version. There are a lot of options not available with the LE (light edition).......
Just something to keep in mind
Huey
Huey
Posted Sun 14 Aug 11 @ 5:09 pm
But if he can get an LE serial from numark he will be eligible for a significant discount on PRO.
Posted Sun 14 Aug 11 @ 5:13 pm
Good point Bart, I completely forgot about that, lol!!
Huey
Huey
Posted Sun 14 Aug 11 @ 6:00 pm
thank you guys!!!
Posted Mon 15 Aug 11 @ 4:28 am
