Forum: Old versions
Topic: problem with setting up keyboard shortcuts!!
i'm starting to chop and screw a lot of music and i learned the key to it all is moving the cross fader back and forth.
the only problem i have is that i can't get any of the keyboard shortcuts to setup
I tried linking the space bar to the crossfade, it wouldnt work. I've looked at youtube tut's ect.
Can anyone break it down for me please? getting frustrated.
I have windows 7 laptop, running VDJ 6
would i need to download a skin or anything? thanks
Posted Tue 09 Aug 11 @ 3:48 pm
VirtualDJ v6 is an old and out of date version of the software. There have been many changes and improvements to the software since then (See https://virtualdj.com/wiki/VirtualDJ_History.html ) - We are now on v7.0.5
Please register your serial number on the page https://virtualdj.com/users/edit.html and then upgrade to the latest version: https://virtualdj.com/download/updates.html
Or purchase the latest version from the following page: https://virtualdj.com/products/comparison.html
If you are using VirtualDJ for home use only without MIDI controllers/timecode/video, then you can download and use VirtualDJ v7 Home from https://virtualdj.com/download/free.html - This version can be used completely free of charge for non-commercial home use (It may not be used a DJ gigs where you are being paid.)
You will probably need to map keys to instantly crossfade to the far left and right, e.g:
Map J to: crossfader 0%
Map K to: crossfader 50%
Map L to: crossfader 100%
For basic mapping instructions, please see https://virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
For more precise and hands-on control, you would be better purchasing an all-in-one MIDI controller with VirtualDJ LE included such as Hercules DJ Console series, Numark MixTrack Pro, etc.: https://virtualdj.com/products/hardware.html
These have a real crossfader that you can move by hand as fast as needed.
hey im in need of some mapping help. iv messed around with the v. dj before, but my homie had it to where the number pad on the right would skip forward and backward. thas how i was choppin but now that iv got a laptop, i dont hav the num pad. does ne one know what the action is called so i can map it to other buttons????
