just curious does this update address the denon 3700s jog pulse resolution advancement , is vdj capable of operationg with denon 2960 cylce setting which effectively doubles the platter resolution of DN-S3700
normal setting is 1480, which is definitely not on point while running the vdj software and using the midi setting -- djk --
Posted Tue 09 Aug 11 @ 4:44 am
beatbreaker1 wrote :
Like Chris said........
cstoll wrote :
IE9 gives that message with any EXE or MSI install file ...
but that is not true, i download several different files and none of them give this sign
Posted Tue 09 Aug 11 @ 11:23 am
HELLO VDJ
Posted Tue 09 Aug 11 @ 9:11 pm
VDJ IS THE BEST
Posted Wed 10 Aug 11 @ 8:00 am
Please have a look at the first post in this thread. The link to the Wiki will show you all changes in this update.
sclavel wrote :
As usual, the complete change list can be read on the wiki
Posted Wed 10 Aug 11 @ 11:12 am
Hi guys, I feel the response to DJ JAMM's point is a bit too easy. First of all, the wiki about 7.0.5 is cryptic. Secondly, the possibly related change "jogfull" is not in the script wiki. Thirdly, last week in the archives I read a promise (!) by VDJ staff, that this platter resolution increase "will be in the next release". So I feel a direct answer is justified. Thanks in advance & keep up this gr8 product !! (and I'm sure, JAMM just used caps to cheer us all up ;-))
Best,
Arie
Best,
Arie
Posted Wed 10 Aug 11 @ 2:30 pm
OK, so I found it. I was referring to this comment by cstoll on Mar 8 2011, in reply to dustinash:
"Now if you are running in PURE MIDI mode - then yes, the resolution would make a difference. An update to the MIDI definition did not make it into this recent release for increasing the resolution. It will be in the next release." You can find this on:
http://fr2.virtualdj.com/forums/115215/Hardware_Technical_Support/DENON_Hardware_Products_(Setup__Solutions__Fixes__Issues__etc_).html?page=25
Have a fine day,
Arie
Have a fine day,
Arie
Posted Thu 11 Aug 11 @ 3:35 am
s.waterreus wrote :
am i the only one getting this, not shocking and i know it's nothing but it doesn't look friendly.
IE9 standard settings
Internet Explorer is rarely used now days. Google Chrome or Firefox is common
Thanks for the updates
Posted Thu 11 Aug 11 @ 4:02 pm
help! is 7.0.5 solve Denon dnhs 5500 midi problem? i been waitin for change since vdj 7.0.0?
Posted Fri 12 Aug 11 @ 9:04 pm
fixed changing vinyl mode/cd mode while touchwheel_touch is kept pressed
So does this mean when I press the vinyl scratch button on my VMS4 on can still have my hand on the jog wheel?
Posted Sat 13 Aug 11 @ 1:31 am
I have just tried 7.05 but reverted back to 7.02 . Bug issues with music videos , they keep freeze then carry on then freeze again... Super spec computer so I know its not that... 7.02 working fine again .. just be aware and check at home first before you go live case you have similar issues...
Posted Sat 13 Aug 11 @ 6:35 am
haha, im only like a week late on noticing this.
Posted Sat 13 Aug 11 @ 5:14 pm
Are the issues with videos on windows or OSX as I am not going to risk it until fixed
Posted Sun 14 Aug 11 @ 4:07 pm
The problems are with windows 7 64 bit .. the video format we are using is mp4.
Hope this helps..
Hope this helps..
Posted Mon 15 Aug 11 @ 6:58 am
I too would like to know if problems with Denon 5500 will be fixed, I am unable to use VDJ at the moment because of this.
Posted Mon 15 Aug 11 @ 11:24 am
Hope this helps..
Hope this helps..
has anyone had problems with Windows 7 32 bit or is that ok
Posted Mon 15 Aug 11 @ 12:12 pm
what i learned when upgrading is, factor reset after it seen to give the best results.
Posted Mon 15 Aug 11 @ 6:19 pm
Thank You VDJ for all your hard work!
Posted Mon 15 Aug 11 @ 9:46 pm
I've been using 2 dn-hs5500s in midi without problems since ver 7.03. I have no warbles or sound issues. What problems are you guys having? Perhaps its a setting issue?
Posted Mon 15 Aug 11 @ 10:06 pm
Hi sir.. may i know your setting for vdj 7.0.3?
i believe vdj receive a lot of complain abt denon dnhs5500 in midi mode
my issue is the spin platter not stable warbles especially when i change to player 2.. pls help tks so much..
Posted Tue 16 Aug 11 @ 8:45 am
