Hello
I am trying to broadcast but it does not seem to work
Its an Ogg.file
I see you can do an MP3.file format but i dont have a clue what the encoder is all about
Anyone help?
Thanks
Its an Ogg.file
Anyone help?
Thanks
Posted Fri 05 Aug 11 @ 5:32 pm
You need to download the lame_enc.dll and put it in your Programm folder. Then select the lib in your Broadcasting section to enable the mp3 usage.
Greets, Heiko
Greets, Heiko
Posted Fri 05 Aug 11 @ 5:51 pm
where do i find this file?
Posted Fri 05 Aug 11 @ 5:54 pm
Posted Fri 05 Aug 11 @ 5:56 pm
thankyou very much
Posted Fri 05 Aug 11 @ 5:59 pm
I changed the web link..is there a standard weblink?
Posted Fri 05 Aug 11 @ 6:03 pm
Not shure what you are talking about - sorry.
Maybe you should read some basics ?
https://virtualdj.com/wiki/Broadcasting%20Howto.html
Greets, Heiko
Greets, Heiko
Posted Sat 06 Aug 11 @ 4:36 am
