Hi
I recently purchased a RMX and now getting to grips with it as I havn't mixed for about 10 years. Anyway all is set up but for some reason it just cuts out and doesn't work, the virtual DJ carries on but the actual units nothing happens until I take the power leas out and start again.
It might be ok once i put the lead back in but it has happend on a few occassions and I dont kno wif I am doing something wrong or there is an issue with my RMx unit?
If anyone has experienced this in the past or know if this is a known problems then your help wouls be appreciated.
Thanks
Thanks
Posted Fri 05 Aug 11 @ 3:22 am
hi
when u open vdj go to setup(settings) then in sound setup go down to sound card. open and high light the rmx as ur sound card and hit apply then ok, this should take care of the problem.
Posted Fri 05 Aug 11 @ 2:32 pm
Hi mate
If your computers power management settings are shutting the USB power down after a time this could also cause the problem you are having.
Daz
Daz
Posted Sat 06 Aug 11 @ 6:02 am
update driver?
Posted Mon 15 Aug 11 @ 6:13 pm
