Hello, anybodu knows the mapping values for denon hc-4500 to autocrossfade from one deck to another
so i can mix video??? i have not a midi mixer so i need that mapping value to do that , thanks!
Posted Wed 03 Aug 11 @ 8:44 pm
Got it!
Para el deck izquierdo. video_ crossfader 0%
mantener en medio el fader. video_crossfader 50%
Para el deck derecho. Video_crossfader 100%
now...how can i make it fade progressive? i mean it turns 3 seconds for example between one deck to another??
Posted Thu 04 Aug 11 @ 1:11 pm
Map a button on your Denon as
video_transition 500ms
or choose different value to adjust the duration (ms) of the crossfading
Posted Thu 04 Aug 11 @ 1:29 pm
ok, and that value have to be set in the same line that the previous map? or where?
Posted Thu 04 Aug 11 @ 2:29 pm
Just use the learn command, press the button then manually enter the text above in the box.
Keith
Keith
Posted Thu 04 Aug 11 @ 2:43 pm
Really thanks Keith!!!
Posted Thu 04 Aug 11 @ 4:08 pm
