@DjKlepth,
Here you go, this will show you how to get a better scratch.............
And it should work cause Ive donr it with my Mixtrack
Enjoy
Huey
Posted Tue 02 Aug 11 @ 7:06 pm
Thank for the video and nice scratching. I was told a while back that the mixdeck could not be used to mix videos in VDJ because the mixer section was not midi. Is that still true?
Posted Tue 02 Aug 11 @ 7:41 pm
You can mix videos with a Mixdeck, I do it all the time........and if you watched the video I showed you which knob I had mapped for the video crossfader, lol!! But with the Mixdeck Quad the mixer section is MIDI so you won't have to map the video crossfader to a spare knob........
Good Day
Huey
Good Day
Huey
Posted Tue 02 Aug 11 @ 8:00 pm
Blulite wrote :
when you return it to the point its supposed to be. it still makes the pitch jump. im really not happy wit the way they work. i need to do some serious tweaking.
Check your pitch range in CONFIG -> Options - It may be that you are using a pitch range that it too wide, resulting in course adjustments.
In particular, if the pitch slider only has 7-bit resolution (Common on most budget controllers), then you should use a range of no more than 6%.
Please see https://virtualdj.com/wiki/MIDI%20controller%20pitch%20precision.html
Posted Wed 03 Aug 11 @ 5:40 am
thanks SS, ll try that later.
Posted Wed 03 Aug 11 @ 12:37 pm
Hey I need help changing the numbers in the registry as well.. I have tried changing a few but none seem to get rid of it. I don't really know wht each one is exactly doing though. The problem I see is that when I scratch it takes a lot of time to pick back up on the song or sample so i cant scratch vocal loops or cues well.. any help greatly appreciated.
Thanks,
DJ Cool Colors
Thanks,
DJ Cool Colors
Posted Sun 07 Aug 11 @ 7:33 pm
You really shouldn't change any thing in the registry unless your sure you know what your doing. I'd return it back to factory settings then open the registry tool with VDJ closed. Next find the line that says 'default scratch latency ' and change it to 1024. Now close it and open VDJ. Then scratch away.
Enjoy
Huey
Enjoy
Huey
Posted Sun 07 Aug 11 @ 9:09 pm
In particular, if the pitch slider only has 7-bit resolution (Common on most budget controllers), then you should use a range of no more than 6%.l
worked perfect, thanks SS. now i need to try out hueys scratch settings. but im stll a bit rough off the weekend so im watching a bit of tv today.
Posted Mon 08 Aug 11 @ 9:46 am
I just realised on my mixtrack if i connect the rca cable to output 1 i can hear both decks at same time no matter where the cue is or the crossfader is, but if its from output 2 it only plays where the crossfader is.
Any ideas?
Any ideas?
Posted Tue 09 Aug 11 @ 4:16 am
do
Inputs = None
Outputs = Headphones > Master : chan 1&2 / Headphones : chan 3&4
Sound card = Numark
this will give you headphones from either 6mm jack or second RCA, and your speakers from RCA set 1.
Inputs = None
Sound card = Numark
Posted Tue 09 Aug 11 @ 5:06 am
Hey blu
just realised im an idiot and didnt read my outputs properly hahaha had them the wrong way around lol
thanks mate
thanks mate
Posted Tue 09 Aug 11 @ 6:11 am
no worries mate, anytime. lol. i think most of us have had these brain fart moments that boggled the mind.
im still working on my jogs, they are really really poo for scratching. im getting a delay all the time. im not sure if my scratching style is too fast or the MTP is too slow.. lol. im upping a vid to you tube now to show just how awefully bad it is. i just wish my cdj wasnt in bits at the moment so i could do a comparrison video. my TT's arent hooked up either cuz i need a new soundcard lol. grrr...
Posted Tue 09 Aug 11 @ 6:18 am
heres how my scratching is playing up on my MTP, the delay is insane, i just cant work out how to get rid of it. ive tried hueys tweaks and still nothing. there seems to be very little jog responce. any ideas??
oh and i dont know how to embed vids on here so help wth that would be good too lol.
http://www.youtube.com/watch?v=pnwZsM1JmGk
Posted Tue 09 Aug 11 @ 6:41 am
its too hard to tell, as the video is out of sync with the audio
Posted Tue 09 Aug 11 @ 6:46 am
