Hello all,
I am looking into buying my first controller and cannot decide which to go with out of the two.
My budget is around the £150 mark, of which both can be bought for around this price on eBay (RMX would be second hand).
I am looking to open a small bar (max 50 people) in the next few months, and would be playing for 6 hours 3 times a week so quality is an important issue which made me thought of the RMX rather than the plastic Numark. Although I preffer the appearance of the Mixtrack pro as its bigger and has bigger controll wheels. I would be running the controller with Virtual DJ pro 7.
I've read through countless threads with positive reviews about them both, but head to head which comes out the best? And why?
It will be used for House/Dance/Trance/Electro, no scratching.
Thanks
Thanks
Posted Mon 25 Jul 11 @ 8:01 am
Well if your not going to be scratchin then go with a RMX, its built better, its smaller and stay away from the used units. Why cause its electronics, they can go up in smoke at anytime. Also the RMX comes with VDJ le and with that you cam get a huge discount on the pro version. So my advice is to borrow a buddies setup or take him with you split the pay and save for a brand new RMX. In the end you'll be much happier you did.
Good Luck
Huey
Good Luck
Huey
Posted Mon 25 Jul 11 @ 12:36 pm
