Lion is out and was thinking about upgrading. Only snag is whether or not VDJ will run on it. It is pretty stable on Snow Leopard right now, not sure if it will be on Lion.
Can anyone "in the know" tell if it will run?
Posted Thu 21 Jul 11 @ 9:10 am
Virtual DJ 7 is fully compatible with Lion and has even been listed as fully compatible on skratchworx website
http://skratchworx.com/newspage.php4?fn_mode=comments&fn_id=1754
Posted Thu 21 Jul 11 @ 9:19 am
Well I don't know if Scratchworx is realiable.
This site shows "not tested" http://roaringapps.com/apps:table/p/17
Posted Thu 21 Jul 11 @ 9:25 am
Plus DJ Cyder from Automix has been testing it for months and has said its good to go.
https://virtualdj.com/forums/148950/MAC_Version_Technical_Support/OS_X_Lion_coming_in_July_____.html
Hope this helps.
Hope this helps.
Posted Thu 21 Jul 11 @ 9:28 am
Guess the only way to find out is to try it. HAHA
Thanks for the links!!
Posted Thu 21 Jul 11 @ 9:46 am
Please use the Mac Forum and specificly the thread provided above to discuss this topic.
FYI - yes, VirtualDJ runs on Mac OSX Lion.
Topic Locked
Topic Locked
Posted Thu 21 Jul 11 @ 10:56 am
