I have searched and searched over and over and can not find anything on the Drum Pads on the MPK Mini. I want to try and map them to a Drum Kit in Logic. Does anyone know if this is even possible and any idea how to do it? I have spent countless hours since getting this MPK Mini and still nothing. I know you can assign them to functions or parameters, but can you assign them to Instruments?
Thanks
Thanks
Posted Wed 20 Jul 11 @ 10:00 pm
I use fruity and you can, by selecting "link to last changed parameter" so logic being better than fruity I would say yes, check the manual. If it's for using VDJ and logic in Rewire you can't as VDJ will use the whole device no part of it. Some pluggins also have a midi learn function, but you have to disconnect the device from the daw, by going into options, then connect it to the pluggin, but an easier way would be to map the drum pads to the corresponding note values of the drum hits, or use fruity then I could help you... LOL
Posted Wed 20 Jul 11 @ 10:28 pm
Well no FL for me, I'm using Logic and still cannot figure it out. Thanks anyway. lol
Posted Thu 21 Jul 11 @ 10:34 pm
