So I posted this in the MAC section and didn't get much help, so I'm seeing if anyone here will help me. Im essentially pasting my thread from the other section. Thanks in advance for your help.
im new to all this and doing it for my own enjoyment, not to dj anywhere or something so i knew when i bought the cheap soundcard i'll have to give up something. well im using a numark mixtrack with vdj le/ behringer 60 watt bass/ keyboard amp i have since i play bass. this is the soundcard i have at this point, http://ecx.images-amazon.com/images/I/21fMwoMoH9L._SL500_AA300_.jpg. its not much and i understand that. ive spent the last hour on my macbook on trying to get my headphones to cue, but i've had no luck. im not very tech savvy as you can see.
i have a macbook that has one internal soundcard. i then went ahead and got that other usb soundcard that was in the first picture. i have my numark mixtrack plugged in through one usb port and in the other usb port i have a usb extension with four usb outlets as i cant plug in both my mixtrack and usb soundcard as the usb ports are to close together on my laptop. i have a cable running directly from my laptop to my speaker, and have my headphones plugged into the usb soundcard. from there one i am confused. i have done every configuration under vdj le and im not getting any sound from anywhere. again id appreciate any help
these are the options im getting under vdj le.
output: master second card/ headphones first card
then for soundcard it says
soundcard: gives me two options of built in output, or c-media usb headphone set.
sound is coming from the speaker, but when i press cue on my mixtrack nothing is coming from the headphones, both decks are coming out of my speakers.
Posted Tue 19 Jul 11 @ 11:48 am
hiya mate, check out the mixtrack pro headphones setup guide in my blog on my profile page here at vdj.
there is an advanced setup listed in there that will solve your problems whether your on the mac or the pc.
hope it helps, john.
Posted Tue 19 Jul 11 @ 3:21 pm
thanks for the suggestion, but i finally got it to work. my cue volume was 0, i feel sooo dumb. hahahaha the sound of the cue is great and theres absolutely no lag!
Posted Tue 19 Jul 11 @ 5:59 pm
lol it happens to everyone at some point dont worry. sometimes we get so wrapped up in the advance system setups, we overlook the obv.
glad your sorted now though.
Posted Tue 19 Jul 11 @ 6:15 pm
