he's on youtube with some "how to scrip your Jogs" for some cool control!!!
[youtube]0-3KYwfwyaI&feature[/youtube]
Now can someone translate italian?....
Posted Sat 16 Jul 11 @ 7:25 pm
I cant speak Italian, but i do speak script...
he is just making a shift so the jog operates the filter like pioneer cdj400's, the only problem with it is a) that filter is crap, and b) there is no visual reference for the filter position... if you were able to map the vu meters leds individually you would have something really powerful to work with
you'll need this
http://studio-qb.com/qb-filter
if you want to try it use this
button to change mode
toggle 'modeleft' & deck left effect "qb_filter" slider 2 60% & deck left effect "qb_filter" slider 3 50%
led for button
var 'modeleft' 1 ? blink : off
jog 1
var 'modeleft' 1 ? param_greater 50% ? deck left effect "qb_filter" slider 3 +1 : deck left effect "qb_filter" slider 3 +1 : param_greater 50% ? deck left jogwheel +0.01 : deck left jogwheel -0.01
mapping for skin knob
var 'modeleft' 1 ? deck left effect "qb_filter" slider 3 : deck left effect slider 1
you need to replace left for right for the other deck, but in my opinion without a visual reference, your better off using an absolute knob with
deck left effect "qb_filter" slider 2 60% & deck left effect "qb_filter" slider 3 & param_equal 50% ? deck left effect "qb_filter" active off : deck left effect "qb_filter" active on
you'll need this
led for button
jog 1
Posted Sat 16 Jul 11 @ 11:25 pm
I knew you would jump on this.... LOL....he,he
Posted Sat 16 Jul 11 @ 11:38 pm
I do like the sound of my own er.... typing LMOA!
Posted Sat 16 Jul 11 @ 11:51 pm
