i just recently got my mixtrack and installed virtual dj software it comes with it. I am thinking of paying the premium member subscription. Will i be able to use the netsearch feature on the software version the mixtrack brings? or will i have to upgrade my software aswell? thanks in advance for the help.
Posted Fri 15 Jul 11 @ 2:26 am
The LE version should work fine with Netsearch. just make sure you put your online credentials into the config settings under the internet tab.
Welcome to the madness :)
Posted Fri 15 Jul 11 @ 3:21 am
Netsearch is available to all versions of VDJ and LE is supported.
Keith
Keith
Posted Fri 15 Jul 11 @ 3:23 am
Welcome!!!!!!!!!!!!
Posted Fri 15 Jul 11 @ 6:07 am
i am also thinking of buying the mixtrack(not pro).
i was wondering if i can write scripts in the LE version i get with it.
i want to write script mainly for beat jump (i.e. seek ) and for different play options (like play with sync etc.).
i am also considering gemini ctrl-one.
can't decide which one to buy ?
help !!
help !!
Posted Sun 17 Jul 11 @ 9:19 am
save up more and get the mixtrack pro, and yes you can script with the LE.
Posted Sun 17 Jul 11 @ 10:14 am
Blulite.. i was just going through other topics, i see you everywhere. lol
thanx.
well about the saving thing, this is best i can save as i am just a student. i live in india and i am shipping this from US so i also have to pay for custom and taxes etc.
i have one more question about the mixtrack.
can i use a usb sound card to pre listen tracks in headphones. i have just one headphone jack in my laptop which i want to use as master out.
here is the usb sound card i am talking about..
http://www.amazon.com/External-Channel-Adapter-Notebook-Laptop/dp/B000TYR14U
thanx.
Posted Sun 17 Jul 11 @ 11:20 am
haha, yup, i get about a bit...i dont work at the moment so i entertain myself with the forums and my equipment. well, and food...
if you live in india, why are you shipping from america? you could ship from uk or china for less. if you order from china it is very rare you will pay import tax due to parcels being sent as gifts. americans dont seem to have cottoned onto sending gifts yet..
the soundcard you have chosen is fine to use. i suggest these little things for new starters or even pros if your on a budget or want something thats expendable.
if you need any help at all with setting up your soundcard. goto my profile and check out the Headphone Setup and usage guide. everything you need is in that article.
Posted Sun 17 Jul 11 @ 11:44 am
ya i have already read that guide :)
(i told you i see you everywhere )
can you suggest me any sites of uk or china from where i can buy it
currently i was thinking ebay !
Posted Sun 17 Jul 11 @ 11:49 am
how much is it costing you in total from america? ill have a look around and see if i can find a better price where you wont have to pay import tax.
Posted Sun 17 Jul 11 @ 12:20 pm
ok, what ive found out so far, is a lot of people seem to be buying products from australia, dubai and abu bahbi instead of the states.
shipping from australia seems to be a lot cheaper than shipping from the states. there are 3 stores ive found in dubai
the first which is an authorised distributor for Numark products, is sonia electronics.
http://www.soniaelectronic.com/
the next is nmk electronics also in dubai. im not sure if they sell numark products, but they should be able to help if sonia cant.
http://nmkelectronics.com/
the third is DJ Corner. also in dubai, these guys seem to hve a great selection of dj gear from both the low and high end of the market.
http://www.djcorner.ae/
i suggest contacting these three stores first before making up your mind. if you decide to import, i suggest mporting from Australia from ebay. ive had a look on the ebay china site and they dont seem to have any mixtracks listed. im not sure if im doing something wrong, but i cant seem to find any on there.
you can also speak to numark and ask about distributers in japan and china. there is a really good chance you will be able to afford the mixtrack pro if you do some more digging.
Posted Sun 17 Jul 11 @ 1:24 pm
its 12000 INR
that is around 270 USD !!!!
i also checked ebay china but couldn't find anything.
Posted Sun 17 Jul 11 @ 9:06 pm
i checked these sites online and a few more of australia...
it comes with traktor LE !!!
so won't work for me.
Posted Sun 17 Jul 11 @ 9:27 pm
The thread was originally about using the NetSearch service with the LE edition of the software. And the answer is: Yes, it will work in that particular version.
Let's not hi-jack fattydakid's thread guys.
Posted Sun 17 Jul 11 @ 9:40 pm
Closed as irrelevant by AMAHM
Posted Mon 26 Mar 18 @ 6:49 pm
