Hi there!
I have a problem with the installation of drivers for Hercules mk2. When you insert a disc and try to install drivers, it appears that the new package drivers came out and did not install the original drivers. After downloading the new package and try to install the operation can not complete. Can you help? thanks
Posted Mon 11 Jul 11 @ 5:15 am
Imac G5 PowerPC Mac Os 10.5.8
Posted Mon 11 Jul 11 @ 6:24 am
So let's resume the situation clearly:
You are currently trying to install the latest driver package (v2.71) and the process does not complete. Correct ?
Can you be a little more precise about what exactly happens ?
Was the console installed previously ? What's the reason why you had to reinstall the driver ?
Posted Mon 11 Jul 11 @ 10:45 am
Do not use the console some time. Recently I have tried to use to install drivers from CD Virtual DJ because I did not recognized the console, but I go this message "You cannot install DJ Series Install Package on this volume. A newer version of this software already exists on this volume ". Then I tried to install the new driver package (v2.71), but the process was not completed.
Posted Mon 11 Jul 11 @ 1:50 pm
Тhe console was installed previously.
Posted Mon 11 Jul 11 @ 1:58 pm
please tell me how to fix this error? Thanks
Posted Tue 12 Jul 11 @ 4:40 am
Check your Private messages in your profile.
Posted Tue 12 Jul 11 @ 10:45 am
Hello! I tried to install driver package 2.22 but they could not be completed. Please Please Please help how to fix this problem. thanks
Posted Sat 16 Jul 11 @ 9:44 am
