hi i use the vestax typhoon with virtaul dj pro and im trying to use my akai mpd 24 to use the pads for cue points and fx along with my typhoon but i have absolutely no idea how to get the mpd configured. can anyone help point me in the right direction? thanks!
Posted Sun 10 Jul 11 @ 8:38 pm
use key learn to select the pad, knob or slider... then
deck # hot_cue # (for hot cues, just replace # with the applicable number)
deck # effect "effect_name" active (for effects)
You should register your serial so your pro can receive updates
Posted Sun 10 Jul 11 @ 10:35 pm
hey thanks a lot man! got it all working now. another thing though, im able to map a pad to play the sampler but is there anyway i can map multiple pads to all the different samples i have in my sample bank. i wanna be able to quickly play multiple samples without having to select each individual one for the sampler on the deck interface
Posted Wed 20 Jul 11 @ 10:03 pm
Try,
'Sampler 1 play_stop & sampler 2 play_stop & etc. etc...'
Hope that helps
Huey
Hope that helps
Huey
Posted Wed 20 Jul 11 @ 10:21 pm
