i just got the virtual DJ im trying to play song but it only plays part of the songs :/ can any1 help?
Posted Sat 09 Jul 11 @ 4:59 pm
you need to be more specific in order for anyone to help you.
What version of the software are you using? LE, Home, Pro, etc
Are you using a Controller? MixTrack, Hercules RMX, Numark, Denon, etc
Posted Sat 09 Jul 11 @ 5:43 pm
if the "sampler" tab is highlighted , click on "browser"
Posted Sat 09 Jul 11 @ 6:12 pm
by the sounds of it to me, the tracks arent loading fully before the track is played, this is caused by low spec or cramped systems that cant handle the loading process due to the extra load on system resources.
please can you provide us with your laptop/pc specifications and what version operating system and vdj software you are using.
Posted Sat 09 Jul 11 @ 7:07 pm
Apparently you re trying to load and play songs from Netsearch. In order to fully use (stram/download) Netsearch files, you will need to join Premium Membership.
As a non Premium member you will be able to play just 30 seconds of Netsearch songs.
If you wish to exclude Netsearch files from search results, disable Netsearch Audio and Netsearch Video from the search options menu (small button on the right side of the search bar), or simply disable Use Netsearch option from Config->Internet tab
Posted Sat 09 Jul 11 @ 9:45 pm
