yup another one, anyway, what i need help and advice on is this, i have began video mixing and i would like to remap my MP3 e2 to suit. however i would also like to keep my current configuration.
what i would like to know is, would it be possible to somehow map the automix button to switch between mappers at the press of a button?
Posted Sat 09 Jul 11 @ 8:23 am
the short answer is yes...
but there is a long answer to go with it...
you don't really need to change the mapping for every single key, as you probably won't want to change the eq's between the two settings, you can of course but it seems a little pointless...
the tools you will need are
automix shift button
toggle 'auto_shift'
anything else you want to change the mapping for... It will work for button, jog, knob, slider, LED... anything
var 'auto_shift' 1 ? action when shifted : action when not shifted
the other script you will need to use is the device_side script to assign it to a side of your controller that is just
device_side 'left ? action for left side : action for right side
then paste it all together
device_side 'left ? var 'auto_shift' 1 ? deck 1 action when shifted : deck 1 action when not shifted : var 'auto_shift' 1 ? deck 2 action when shifted : deck 2 action when not shifted
if you break it down into steps it's not too hard to understand, if you want an example so you can see how it works just tell me what you want
toggle 'auto_shift'
Posted Sat 09 Jul 11 @ 8:57 am
where might i find the syntax for activating video effects?
i tired a few variations with the video_fx and effect names but i cant get my effects to activate. i know im doing something wrong... could do with a list really..
Posted Sat 09 Jul 11 @ 10:50 am
one has already been created it's called the wiki LOL, but this is how to choose and activate a specific effect
video_fx_select "strobe" & video_fx
Posted Sat 09 Jul 11 @ 10:55 am
hmm, i must have had a brain fart cuz i looked in the wiki for a list and couldnt find one... lol.
the toggle 'auto_shift' command isnt working i remapped the automix button to
toggle 'auto_shift'
and then i mapped button 5 to
var 'auto_shift' 1 ? effect 'flippindouble' active : effect 'flanger' active
to test the syntax, however the toggle 'auto_shift' doesnt seem to work so i have no idea if the syntax for the variable works.
any ideas?
toggle 'auto_shift'
any ideas?
Posted Sat 09 Jul 11 @ 11:21 am
is the automix button in the middle of the controller (global) or on each side of the controller (local)
Posted Sat 09 Jul 11 @ 11:28 am
its global.
the syntax tip gave me a syntax error and suggested
'toggle "auto_shift"'
which still gave me an error and told me to remove the last '
still nothing. for some reason the controller is still acting like its not had any map changes. ive removed other mappers and restarted vdj, still nothing. i also moved my variable syntax to another button to check to see if it wasnt a double shift problem. thing is, for some reason some of the changes aren't being registered correctly.
Posted Sat 09 Jul 11 @ 11:44 am
try this
device_side 'left' ? var 'auto_shift' 1 ? effect "flippindouble" active : effect "flanger" active : var 'auto_shift' 1 ? effect "flippindouble" active : effect "flanger" active
Posted Sat 09 Jul 11 @ 11:53 am
i got the button to sort of work, it now lights up...lol.. the syntax i used is
toggle 'auto_shift'
however it doesnt seem to be toggeling anything. ill try your above suggestion and let you know
toggle 'auto_shift'
Posted Sat 09 Jul 11 @ 11:58 am
actually you might need this for the shift button
device_side 'left' ? nothing : toggle 'auto_shift'
Posted Sat 09 Jul 11 @ 12:02 pm
nope, that didnt work either.
Posted Sat 09 Jul 11 @ 12:04 pm
grrrrr, after 3 hours of more messing around im still no further forward.
i have my automix button mapped to
toggle 'auto_shift'
and my button one mapped as.
var 'auto_shift' ? effect 'flanger' active : effect 'flippindouble' active
its tried all kind of varied syntax to try and get this to work, but its not doing what its told....any more ideas???
it seems as though there is no connection between the toggle and the variable. there seems to be something missing to link the two.
toggle 'auto_shift'
Posted Sat 09 Jul 11 @ 4:39 pm
finally got it synth :D
heres what i used
toggle $auto_shift
var $auto_shift ? effect 'flanger' active : effect 'flippindouble' active
now i just need to map all the buttons how i want them with my video effects and regular effects. there is some more advanced mapping i want to add too so i may be back with more questions.
heres what i used
toggle $auto_shift
Posted Sat 09 Jul 11 @ 5:07 pm
heres what i have mapped out so far
pitch knob remapped to indrease/decrease bpm by 1.00
pitch bend remapped to increase/decrease bpm by 0.01
sync remapped to stop
automix remapped to "shift" to control video effects
video effects mapped to buttons 1-8 plus track skip << & >>
video effects are activated by pressing the automix button
then activated as follows
1: boom
2: boom auto
3: negative
4: electric shock
shift button active
5: shaker square
6: pandoras box
7: video cube
8: video rotation
track << : titler
track >> : camera
audio effects are as follows
1: flanger
2: beatgrid
3: flippin double
4: backspin
shift button active
5: loop 1
6: loop 2
7: loop 4
8: loop 8
i would like to add audio effects also to track << & >> but will work this out tomorrow.
also i would like possibly to have audio one side and video the other though im not sure that would work
too well unless i had a mapping for deck selection. i suppose i could modify the 4 deck mapper to have
audio for deck 1 & 2 and video for 3 & 4.
im not wholely decided yet and will continue to build as i go. im aiming to build an advanced video/audio mapper for the MP3 e2 that will make it a hugely powerfull controller thats easy to use.
1: boom
2: boom auto
3: negative
4: electric shock
shift button active
5: shaker square
6: pandoras box
7: video cube
8: video rotation
track << : titler
track >> : camera
1: flanger
2: beatgrid
3: flippin double
4: backspin
shift button active
5: loop 1
6: loop 2
7: loop 4
8: loop 8
Posted Sat 09 Jul 11 @ 7:02 pm
nice one blu... It's good to know finally that, that is how $global shifts work...
for the audio one side, video the other you should be able to use
device_side 'left' ? audio action : video action
with the shifted function you could use...
device_side 'left' ? var '$auto_shift' 1 ? audio action shifted : audio action not shifted : var '$auto_shift' 1 ? video action shifted : video action not shifted
but it seems a little crazy to me mapping your controller this way... LOL
Posted Sat 09 Jul 11 @ 11:37 pm
why crazy?? lol. the controller is capable of so much more than its basic settings. people have no balls lol i wanna push it to the max and give it an ultimate mapper make over.
Posted Sun 10 Jul 11 @ 12:20 am
LMAO, go blu go!
Posted Sun 10 Jul 11 @ 12:26 am
lol, ill be a pro mapper in no time at this rate.
though im having a little trouble with my track << & >> mapping, i want it to perform 3 actions
seek -/+ 4
unless shifted then do brake
but if automix button is pressed do titler
the syntax ive been working on is
var $auto_shift ? video_fx_select "titler" & video_fx : var $shifted ? effect "brake" active : seek -4
to me this says
if switch is on, do titler, other wise, is shift active? if shift is on do brake, otherwise do seek
however, the command "shifted" doesnt seem to be doing anything. ive got it to do seek and titler, but it for some reason wont recognise when the shift button is pressed.
any idea??
seek -/+ 4
to me this says
any idea??
Posted Sun 10 Jul 11 @ 1:26 am
that looks right to me, but maybe you need to use '%shifted' I think that localizes the shift to each side of the controller, but not really sure as I've never tried it..
Posted Sun 10 Jul 11 @ 1:34 am
tried it, along with
var $shift
var $shifter
var %shift
var %shifter
even tried
var $shitter
hmm wonder if
& var $shifted ?
if i dont work it out soon i might be
var $shafted
var $shift
var $shifter
var %shift
var %shifter
even tried
var $shitter
hmm wonder if
& var $shifted ?
var $shafted
Posted Sun 10 Jul 11 @ 1:52 am
