Forum: Old versions
Topic: help using VDJ LE that comes with mixtrack pro
hey all..
when i installed vdj le that came with my mxtrack pro...i was not able to configure settings or even use basic keyboard shortcuts so i was forced to use the vdj pro free trial. Now that the trial is over i am back to where i was, i am not able to configure and i cannot even use simple shortcuts such as 'S' for stop!!! These shortcuts come in handy even with when using the mixtrack controller. Can anybody tell me if vdj le is such a "stripped down" version that does not offer these basic functionalities? please help i have a wedding gig on saturday and i need to be up and running asap...thank you in advance!!
Posted Wed 06 Jul 11 @ 12:33 pm
would registering the software help? i really cannot afford to purchase vdk pro right now so i am sincerely hoping vdj le isnt such a colossal waste of time
Sorry, the software that you received with your MixTrack Pro is a free limited edition and does not allow custom mappings, skins, effects, etc. to be used or the program configuration options to be changed (Except during the 20 day trial of Pro.) Please see https://virtualdj.com/products/comparison.html
To be able to use custom settings, mappings, skins, effects and much, much more you will need to upgrade to the full VirtualDJ Professional. Your VirtualDJ LE for MixTrack Pro entitles you to a significant discount (50%) off the cost of upgrading. To receive this, please go to https://virtualdj.com/buy/ and enter your software serial number in the box provided at the bottom of the page.
Before upgrading, you can also try out Pro features in VirtualDJ v7 Home FREE by going to https://virtualdj.com/download/free.html - This software will allow you to test your MIDI controller with it for 10 minutes at a time before reverting back to internal mouse and keyboard control only.
