Forum: Old versions
Topic: Script Help........ - Page: 1
Ok heres my script now,
var_equal "MODE" 1 ? set "RECSAMP" 1 while_pressed : var_equal "MODE" 2 ? sampler 1 play_stop : var_equal "MODE" 0 ? var_not_equal "HOTDEL" 1 ? hot_cue 1 : delete_cue 1 & set "MODE" 2"
I want my sampler to be play_stutter, ok easy enough. I'd just change that part of the script but I want to be able to hold down the button to shut it off.
Any help would be great!
Thanks for looking and the time
Huey
Posted Wed 06 Jul 11 @ 1:12 am
I'm still stuck, can anyone help, please??
Huey
hey huey, I'm not following when you say "hold down the button to shut it off" to me that sounds like you want to pause, stop or silence the sample when you hold the button down but recommence when you release, I know I'm probably wrong, can you elaborate?
Yeah stop the sample when I hold the button down and not restart till I hit the button again. I thought it would be like "sampler 1 stop when held down 500ms"
Huey
that should just be "samper 1 play_stop" like you have done, it should toggle between play and stop on each press, you can't do "holding ? sampler 1 stop : sampler 1 play_stutter" because both the actions have to happen when the button is pressed and so confuse vdj
So if I use the sampler_stutter there's no way to shut it off??
Thanks for the time
Huey
don't you just lift the button as the sampler will only play when its pressed? if that's not working you could use "sampler 1 play while_pressed" maybe you could use "sampler 1 play ? sampler 1 stop : sampler 1 play while_pressed & holding ? sampler 1 play" but you will probably trigger the sample twice... when you press and when you release after half a second
Naw that's cool ill just leave it the way it is and map a few buttons on the keyboard for the stutter.
Thanks for the time bro!!
Huey
Got that shit!! Heres the script,
var_equal "MODE" 1 ? set "RECSAMP" 1 while_pressed : var_equal "MODE" 2 ? holding ? sampler 1 play_stop : sampler 1 play_stutter : var_equal "MODE" 0 ? var_not_equal "HOTDEL" 1 ? hot_cue 1 : delete_cue 1 & set "MODE" 2
The highlighted part is what I changed/added.
Huey
Im not even sure if its possible so here goes,
I would like browser_zoom view when I go to select a track, and switch back to deck view when I load a track. So basiclly everytime I turn my browser scroll knob it'll switch to browser_zoom mode and when I hit my load deck button it'll switch back to the normal view.........
Now, whos up for the task, lol!
Thanks for looking
Huey
Me me me pick me... Huey, huey pick me LMAO
Hahaa! I saw your other post about wanting a hard script, lmao!!
Huey
param_greater 50% ? browser_scroll +1 & browser_zoom 1 ? nothing : browser_zoom 1 : browser_scroll -1 & browser_zoom 1 ? nothing : browser_zoom 1
load button (both decks)
load & browser_zoom 1 ? browser_zoom 0 : browser_zoom 0
if that doesnt work try
browser_zoom & param_greater 50% ? browser_scroll +1 : browser_scroll -1
load & browser_zoom
load & browser_zoom
This looks like the winner so far!
deck 1 load & browser_zoom will load the first deck and kick it back to deck view when in browser zoom.
Ok this 1 opens browser zoom but it wont scroll the tracks,
This 1 flickers, it'll scroll but it switches from normal view to browser zoom as Im scrolling,
Is this a hard one or what, lol!!
Huey
can you try these two buttons I need to know if they work for the code to work properly
browser_zoom 1 (should make it big)
browser_zoom 0 (should make it small)
can you try both buttons in both browser states to make sure they work... yep this will make my day a little more exciting LOL
Yup those both work. Aww sh*t, hes gonna make happen! Lol!!
Huey
just got busy here.. give this a go
browser_zoom 1 ? nothing : browser_zoom 1 & param_greater 50% ? browser_scroll +1 : browser_scroll -1
It'll open the browser but wont scroll..........hahaa!! A tough one, next, lol!
Huey
maybe this
browser_zoom 1 ? param_greater 50% ? browser_scroll +1 : browser_scroll -1 : browser_zoom 1 & param_greater 50% ? browser_scroll +1 : browser_scroll -1
59%
