I have the Mixtrack Pro & I rarely use the loop in & out button so I want 2 change them 2 activate my sample deck....for example loop in button would be sample 1 loop out would be sample 2 reloop would be sample 3....Does anyone know how 2 do this because I went into the settings & mapping tab but it I hit my loop in button and it pops up for me 2 change it 2 something else but I don't see an option for the sample deck.
Posted Sat 02 Jul 11 @ 10:27 am
havent mapped in a long time and also got lots of help.but think i remember from my rmx that it is something like
button 1....sample 1 play&stop
button 2...sample 2 play/stop
hopefully some mappers will chime in.
if you try to map buttons write what you want and syntax in mapping should help you put whats required.
sorry i cant be more help mate as i always got great help from users here
Posted Sat 02 Jul 11 @ 1:03 pm
sampler 1 play_stop (play until you hit the button again)
sampler 1 play_stutter (play sample until you release the button)
Posted Sat 02 Jul 11 @ 10:23 pm
