Hi all,
I have the same issue as discjockeyr.
Master tempo is set to Advanced stretching...
Doesn't matter which CDJ model you use to play timecode.
Any help would be appreciated.
P.S I have also checked version 7.0.4 of VDJ pro and it has the same issue.
Posted Thu 04 Aug 11 @ 3:23 pm
hi nightlife01,
do you also use the finalscratch amp?
Posted Thu 04 Aug 11 @ 4:18 pm
No, I use Virtual vinyl USB device, but it sounds like I have a similar issue.
I'm waiting to hear back from Atomix or Numark regarding this.
I will post if I get any answers.
Posted Thu 04 Aug 11 @ 10:45 pm
Am I the only person seeing nightlife with like 20 copy's of CUE or VDJ7 in his side panel under his name?
Regards Dj Klepht
Regards Dj Klepht
Posted Fri 05 Aug 11 @ 12:48 am
Our issue is very strange. Actually everything working perfect on virtualdj a little that i test it but this issue when you pitch bend with the jog of the cd player the keylock seems that is not working. you hear the pitch of the song changing.
Seems that it is not a configuration as i try all options but an issue between my hardware and the VDJ7 pro and thought that i was the only one having this issue but now appears this issue from "nightlife" which is using different hardware. If anybody can explain this so to not loose hours to find a solution.
Thanks
Thanks
Posted Sat 06 Aug 11 @ 11:06 am
