i just bought a numark dj i/o sound card to use with my total control. the problem im having its that i have my speakers running out of the main sound port of my mac book pro and they sound fine, but the problem is that i cant get any sound out of my head phones. i tried all the possible configurations . when i get sound from my head phones, i wont get sound from my speakers. can anyone help?
Posted Tue 28 Jun 11 @ 8:33 pm
im using virtual dj by the way
You will need to configure your sound card as follows:
Go to CONFIG --> Sound Settings
Inputs: None
Outputs: Headphones (Master: 1&2 Headphones: 3&4)
Soundcard: 4in/4out (Numark or DJiO selected in drop down)
You will then need to connect your sound system to outputs 1 & 2 of the DJ/iO and plug your headphones into the headphone port of the device.
Inputs: None
Posted Tue 28 Jun 11 @ 9:20 pm
im just using the i/o for my head phones. im using just regular computer speakers, the ones u just plug in to the audio port on the lap top.
Posted Tue 28 Jun 11 @ 9:33 pm
In that case:
Inputs: None
Outputs: Headphones (Master: First Card - Headphones: Second Card)
Soundcard: 2 cards (Primary Sound Card)
( Numark DJ/iO )
Inputs: None
( Numark DJ/iO )
Posted Tue 28 Jun 11 @ 10:07 pm
you need an adapter like this:
http://www.salephonehousing.com/product_info.php?language=en¤cy=USD&products_id=777
Nevermind ;)
Nevermind ;)
Posted Tue 28 Jun 11 @ 10:09 pm
i tried that and every other combination and still nothing. so it wont work unless i have that adaptor? do u know why it wont work?
Posted Tue 28 Jun 11 @ 10:16 pm
The adapter would be one way to work around it. You would use the first set of instructions provided by *ACE* and just plug the RCA's into the output of the DJ IO and your 1/8" speaker plug into the adapter. You could probably pick it up locally at Radio Shack they tend to have a good selection of adapters like that.
Fixing it in software like *ACE* suggested in the second reply would be preferable though as long as your built in sound card is decent.
Posted Tue 28 Jun 11 @ 10:24 pm
here is a screen shot of wat i thought was the sure way it would work.
http://tinypic.com/r/2h3wzmo/7
Posted Tue 28 Jun 11 @ 10:46 pm
guys please help. i really dont want to spend more money on something else. i thought with the i/o i was going to be set. i have a gig this weekend and i really need for this to work. any other suggestions on what might be causing the problem. also if i buy the adapter will i get stereo sound. or will it be mono just like any other Y-splitter. if it is mono, how can i get stereo sound?
Posted Tue 28 Jun 11 @ 10:50 pm
This is the exact set-up you need! What problem are you having? What version of the software are you using?
Posted Tue 28 Jun 11 @ 10:55 pm
pro 7
Posted Tue 28 Jun 11 @ 10:56 pm
Try going to http://www.numark.com/djio and updating your drivers.
Posted Tue 28 Jun 11 @ 10:59 pm
the only thing i have conected to the i/o is my head phones. and i have a regular audio cable running from my mac book pro to my speakers. i get sound out of my speakers but no my headphones. i played around with the configuration and i got sound in my headphones but not on my speakers.
Posted Tue 28 Jun 11 @ 11:02 pm
just updated the drivers. didnt fix it
Posted Tue 28 Jun 11 @ 11:12 pm
any other suggestions?
Posted Wed 29 Jun 11 @ 4:25 pm
