Hello.
I recently purchased a Hercules E2 mixer, and I'm using Virtual DJ Pro 7.0.
When I had my fun mixing before I purchased the Hercules E2, there was no "Listen A" or "Listen B" options, which made it easier to have a better control over what I was doing.
Is there a way to disable that feature? It doesn't matter if I'm using headphones or my speakers, because it'll play the music on one side and then the other once I select it.
Thanks.
Thanks.
Posted Sat 25 Jun 11 @ 10:45 pm
config > options and disable Auto cue and auto headphones
Posted Sun 26 Jun 11 @ 3:16 am
